Rady ke QLC+
  • DEMO14
Scully
Re: Rady ke QLC+
Příspěvek od Scully » pon 15. kvě 2017 20:55:32
Tak už to zasejc padá, asi náhoda předtím.
Scully
Re: Rady ke QLC+
Příspěvek od Scully » pon 15. kvě 2017 20:56:41
#0 0x75823f70 in __GI_raise (sig=sig@entry=6)
at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x75825324 in __GI_abort () at abort.c:89
#2 0x75864ec0 in __malloc_assert (assertion=<optimized out>,
file=<optimized out>, line=1995493376, line@entry=3695,
function=<optimized out>) at malloc.c:293
#3 0x75868938 in _int_malloc (av=av@entry=0x759334d4 <main_arena>,
bytes=bytes@entry=129) at malloc.c:3695
#4 0x758690bc in _int_realloc (av=av@entry=0x759334d4 <main_arena>,
oldp=oldp@entry=0xc1ead8, oldsize=oldsize@entry=72, nb=nb@entry=136)
at malloc.c:4286
#5 0x7586a6f4 in __GI___libc_realloc (oldmem=0xc1eae0, bytes=128)
at malloc.c:3029
#6 0x75b681ec in QListData::realloc(int) ()
from /usr/lib/arm-linux-gnueabihf/libQtCore.so.4
#7 0x75b68280 in QListData::append(int) ()
#8 0x76d90808 in QList<QString>::append (this=0x7e996ec0, t=...)
at /usr/include/qt4/QtCore/qlist.h:530
#9 0x76aa8b34 in InputOutputPatchEditor::fillMappingTree (this=0xb72e40)
at inputoutputpatcheditor.cpp:205
#10 0x76aa88b8 in InputOutputPatchEditor::setupMappingPage (this=0xb72e40)
at inputoutputpatcheditor.cpp:176
---Type <return> to continue, or q <return> to quit---
#11 0x76aa8240 in InputOutputPatchEditor::InputOutputPatchEditor (
this=0xb72e40, parent=0x88e528, universe=0, ioMap=0x574dd0, doc=0x57a358)
at inputoutputpatcheditor.cpp:116
#12 0x76aa73a8 in InputOutputManager::slotCurrentItemChanged (this=0x88e528)
at inputoutputmanager.cpp:317
#13 0x76c00be0 in InputOutputManager::qt_static_metacall (_o=0x88e528,
_c=QMetaObject::InvokeMetaMethod, _id=3, _a=0x7e997158)
at moc_inputoutputmanager.cpp:69
#14 0x75c6a2ac in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/arm-linux-gnueabihf/libQtCore.so.4
#15 0x76403980 in QListWidget::currentItemChanged(QListWidgetItem*, QListWidgetItem*) () from /usr/lib/arm-linux-gnueabihf/libQtGui.so.4
#16 0x76403b3c in ?? () from /usr/lib/arm-linux-gnueabihf/libQtGui.so.4
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Scully
Re: Rady ke QLC+
Příspěvek od Scully » úte 16. kvě 2017 8:20:56
Tak nakonec vše běží, jen start někdy padá. Pokud se to rozběhne, tak barvy dle hudby běží. Jde to přes mikrofon i přes audio loopback. V audio triggeru jsou hodnoty pásem asi nesprávné. Testoval jsem na sin generátoru a na sloupci s 5kHz se ukazovala skutečná frekvence 10kHz. Pokud jsem zkusil frekvenci > 10kHz, tak se mi hodnoty ve všech sloupcích zvedly najednou (něco jako bílý šum), detekce vyšších kmitočtů asi nepracuje správně.
Scully
Re: Rady ke QLC+
Příspěvek od Scully » úte 16. kvě 2017 15:58:32
Pls ještě o jednu radu - dá se na Raspberry 3 zvýšit úroveň audia nad 100%? Nemohu najít žádnou rozumnou nápovědu na netu. QLC+ to bohužel nijak neřeší. Nebo jiný nápad? Potřeboval bych to na loopback.
janek
Re: Rady ke QLC+
Příspěvek od janek » úte 16. kvě 2017 16:04:02
- zvysit uroven: neviem
- 10kHz vs. 5kHz: to bude nejaky artefakt zle zvolenych parametrov pre FFT (spektralnu analyzu)
Pawlyk65
Re: Rady ke QLC+
Příspěvek od Pawlyk65 » úte 19. čer 2018 9:17:57
Zdravím, potřeboval bych poradit ohledně automatizace podle hudby. S QLC+ jsem se již poměrně skamarádil a na živé svícení kapel je to pohoda, na ovládání používám kombinaci dotykového monitoru a APC mini. Řešení je i poměrně stabilní takže pohoda. Ale teď problémy...pro ovládání zvukem používám audio-triger, z mixu si pustím pouze "kopák" a ten mi posouvá scény v cuelistu. Dle stylu hudby nastavím "děličku" a další scéna jde třeba po každém 4 šlápnutí...
Pro rock a pod. to je relativně vyhovující, ale pro jiné styly nepoužitelné. Audio-triger je dle úrovně signálu na daném frekvenčním pásmu a když má "málo" nebo "moc" tak nepřepíná. Navíc třeba po kapelách nastoupí DJ a zde je tato varianta také pro mě zatím nepoužitelná. Ideální by byla aplikace, která by běžela na pozadí a "live" prováděla analýzu skladby jako DJ program - a poskytovala MIDI výstup-jen "take" na 1, 2, 4 nebo 8 dobu...existuje něco?
Ještě hardwarový problém - chtěl jsem použít Lexikona Alphu jako zvukovku pro světla, ale když už jí audiotriger začíná indikovat(úroveň) tak je zvuk velmi přebuzen - zvukovka počítače víceméně funguje - jen ten 3,5 jack!...
děkuji za pomoc. Pavel
Hynek1177
Re: Rady ke QLC+
Příspěvek od Hynek1177 » pon 07. led 2019 9:27:23
Prosím o radu. Jsem čerstvý uživatel QLC+. Mám problém, že program mi vůbec nechce načítat aktualizovaný seznam zařízení. Přidám adresář "výrobce" s naimportovaným světlem a QLC+ mi to v seznamu zařízení neukáže. Když si vytvořím své světlo v editoru a uložím jej do složky s ostatními výrobci (do nově vytvořené složky) opět to QLC+ nevidí. Editor to tam vidí a kdykoli to otevře. I světla naimportované odjinud. Jak donutit samotný QLC+, aby si složku ve svém adresáři aktualizoval? mám staženu poslední verzi QLC, win7 profi
Dík za rady, Hynek
Pawlyk65
Re: Rady ke QLC+
Příspěvek od Pawlyk65 » pon 07. led 2019 13:04:30
Do žádná složky nic neukládej...uloží se samo. Originál fixture jsou na c ve složce qlc+/fixtures ale importované nebo vytvořené jsou v users/dokuments/qlc+/fixtures....tam se ukládají automaticky.
Při vytváření napiš v new fixture do položky manufactured třeba "Hynek", vytvoř celou fixture, dej uložit - ukáže ti to cestu do dokumentů - složka qlc+/fixtures - enter.
A v programu dáš "add fixture" a nalistuješ "výrobce Hynek"....a máš tam svoje fixtury...funguje to
bohužel jsou fixtury na dvou místech, ale když už s tím počítáš, tak to jde lehce přenést i na jiný počítač.
Hynek1177
Re: Rady ke QLC+
Příspěvek od Hynek1177 » úte 08. led 2019 13:47:03
Díky moc. Zjistil jsem že mi nové fixture QLC+ načte až po restartu programu a předtím ukončení fixture editoru. Pokud editor nechám otevřený (přestože je fixture uloženo), QLC+ mi změny ve fixtures nevidí.
Pawlyk65
Re: Rady ke QLC+
Příspěvek od Pawlyk65 » stř 03. črc 2019 10:20:15
Zdravím ve fóru, jako snad průměrný uživatel QLC+ jsem se dostal do pasti...zkouším migrovat na MAC a zatím se mi moc nedaří.
program nainstalován - přenesený projekt z win se sice rozeběhne a je částečně funkční, ale hlásí že nemá "moje vytvořené fixtury"... mám je na USB, ale zatím jsem nenašel kam je nahrát, ani fixture editor nepomáhá - otevřu fixturu z USB ale nenacházím možnost, kam ji "funkčně" uložit. Nedaří se mi ani otevřít a upravit stávající fixturu ze seznamu programu...editor je nevidí...má někdo zkušenosti? A jako bonus - APC mini program vidí, je nastaven v IN/OUT...sice přepíná, fadery "tahají" ale tlačítka nesvítí...a to mám podsvícení korespondující s virtuální konzolí na monitoru pro rychlou orientaci při produkci....je mi jasné, že je to moje chyba - čekal jsem přechod na MAC jednodušší...poradí mi někdo??
Zpět na „Software“
