SI firmware 1.7 build 007
  • Powersoft skoleni 2019
janek
Příspěvek od janek » pon 08. čer 2015 11:09:32
...je na webe (Expression, Performer)
New Features:
• Master Fader-Monitor Level Swap added to monitor window
• Pre-dynamics send point added to Per-Channel-Per-Bus pickoff selection
• Global FX Send Masters channel/bus type added
• Insert count increase from 4 to 22
• Alt+Mix (n) brings bus contribution levels onto Global Encoders
• Mute group override: unmute channels in a Mute Group
• "Solo Auto Cancel" mode added to solo preferences
• New contribution pan mode field under "Bus Sends" on output window with three options: 1) Independent Bus Panning 2) Bus Follows Channel Panning 3) Bus Inverts Channel Panning
• Channel strip pan encoder controls bus panning when in bus contribution mode
• "Touch & turn" control of Lexicon parameters
• "Auto Bus Master select" added to preferences
Bug Fixes:
Lexicon FX parameters recalled from bootup
Stereo input channel to stereo bus mix fix
janek
Re: SI firmware 1.7 build 007
Příspěvek od janek » úte 09. čer 2015 14:53:25
Vcera sme to nainstalovali (na performer 2):
znamena ze sa da vymenit monitor level (potenciometer vpravo hore) a master sabla. Potenciometer ovlada master, a sable monitor. Dobre asi do studia, mozno na monitorovy pult (na ovladanie lokalneho monitora).
V kanali sa da nastavit ze do AUXu pojde signal pred gate/kompresorom
sabla FX send master sa da pridat hocikde do vrstvy. Dobre na vypinanie reverbu aby dobehol dozvuk.
zvysili pocet insertov na 22
Stlacenim Alt+Mix N sa na encodery dostanu urovne jednotlivych kanalov pre dany mix. Na sablach zostane hlavny mix (LR). VELMI UZITOCNE! (Monitory, efekty). Stlacenim MIX n sa prepne do "klasickeho modu" - sable su pre MIX N. Neda sa mat na sablach jeden mix a na encoderoch druhy. Vzdy LR + nejaky iny.
ak je zapnuta Mute skupina, stlacenim ON sa da zapnut jednotlivy kanal (a tym ho akoby docasne vyradit zo skupiny)
Netusim
Je mozne mat na stereo auxe inu panoramu ako na LR. 1) PAN kazdeho kanalu do tejto zbernice je osobitne nastaveny, 2) PAN do tejto zbernice je tak isto ako PAN pre LR, 3) PAN pre tuto zbernicu je NAOPAK ako LR
ked je vysvieteny iny mix, tocenim PAN v hornej casti mixu sa nastavuje panorama do tohto mixu (PAN do reverbu naopak ako do LR -- moze byt zaujimavy efekt :) )
Netusim.
Netusim.
Netusim.
Stereo input channel to stereo bus mix fix[/quote]
Netusim.
janek
Příspěvek od janek » úte 09. čer 2015 17:04:19
Je to sice trochu samomluva, ale tie ostatne veci su vysvetlene v komentaroch tu: https://www.facebook.com/SiExpression/p ... 0617196388
Zpět na „Soundcraft“
