Opus Drum Set M
  • sada T10S T7V
mart_xx
Opus Drum Set M
Příspěvek od mart_xx » čtv 03. zář 2009 20:03:41
chlapi mate to niekto? co je to zac?
martin
Fyla
Re: Opus Drum Set M
Příspěvek od Fyla » pát 04. zář 2009 12:05:52
Jaktoze tady jeste neni marketingove oddeleni :?: :-D
Re: Opus Drum Set M
Příspěvek od safa » pát 11. zář 2009 8:32:55
Fila: Priznej se Veverko, tebe to boli ale ty nas chces na*rat :-D
Jasne ze mame, co bys potreboval vedet ?
mart_xx
Re: Opus Drum Set M
Příspěvek od mart_xx » ned 20. zář 2009 15:14:19
chcel som pocut nazory niekoho kto to pouziva
martin
Re: Opus Drum Set M
Příspěvek od safa » čtv 03. čer 2010 20:30:08
Ja to pouzivam, Arakain (Ondra Martinek) to pouziva, Tomas Jakl (Ebeni, ETC a dalsi) to puziva, Honza Polak to pouziva ... a urcite i rada dalsich to pouzivaj. Co bys potreboval vedet ?
Re: Opus Drum Set M
Příspěvek od safa » stř 09. čer 2010 10:45:38
Ted jsem nasel na webu sweetwateru dva uzivatelske nazory na Opus 87 ( http://www.sweetwater.com/store/detail/Opus88/reviews ):
AC Buffalo
from Los Angeles, CA
August 31, 2009
Music Background:
Recording Engineer
Opus 88
I'm usually not a fan of clip on mics, for studio use, with exeption the opus 88. The sound is tight and crisp, and the clamp is strong and stays in place. I used rented a pair from a los angeles audio rentals place whom suggested I give these a shot.
Often when micing snare drums, placing microphones (usually sm57's) on snare, it difficult to get in there and place the top mic, moreover, placing the bottom mic where is even harder; if you think about the fact that you're going to need to reverse the phase. If the mics are not aligned, flipping the phase is going to cause more problems than what it offers.
Long Story Short: if you clip these mics one over the other, on the snare drum, your drum sound will be HUGE.
anyway, I always rent mics, before buying them.
Jay
from MI, usa
December 11, 2008
Music Background:
musician, engineer and producer, over 25 yrs
one of the best tom mics out!!
I have 4 of these and have used them extensively in the studio and quite a few live shows as well. They are absolutely outstanding in either application. Nice full bottom without being boxy. Smooth top end too...not to clicky but nice and clear. Clamp securely to any drums I have encountered yet (pearl, Tama, Gretsch, DW). I do still prefer the Opus 87 or sm 57 on snare though. Again, they are the whip for toms! Get some.
pitrisek.dc
Re: Opus Drum Set M
Příspěvek od pitrisek.dc » pon 22. lis 2010 19:21:22
Zdravím chtěl bych koupit nové mic na snímání přechodů a snare
Chtěl bych se zeptat, jestli je tak markantní rozdíl mezi opus 67 a opus 87.
Na tomy bych si představoval opus 67 a na snare bych vzal jednu opus 87, nebo myslíte, že za opus 67 jsou vyhozené peníze a mám raději pořídit opus 87 i na tomy? Děkuji.
Re: Opus Drum Set M
Příspěvek od safa » úte 23. lis 2010 15:46:50
Levnejsi Opus 67micka ma hur (pevne) ulozenou vlozku takze se do ni obcas maji tendenci prenaset mechanicke vibrace ze chveni bubnu (ostatne neni jediny mikrofon na trhu ktery s timhle ma problem). Oprotitomu Opus 87 ma vlozku ulozenou na dvou pruznych gumovych stopkach takze k prenosu vibraci nedochazi. Pokud muzu doporucit a neni problem trochu prisetrit tak rozhodne Opus 87 nebo Opus 88.
Opus Drum Set M
Příspěvek od TomasVv » úte 31. črc 2012 16:48:01
v sobotu jsem zvučil festival na drum set XXL a musím říct, že to byla naprostá pohoda práce.
Mikrofony mají hezký detailní zvuk, dobře se upevňují na ráfky nebo obruče, nezavazí. Přestože preferuji velkomembránové kondenzátory na OH, true condenser tužky MC 930 splnily úlohu na jedničku (OH AB).
Kopákový mikrofon jsem raději umístil na klasický nízký stojánek, ten originál mi přišel málo flexibilní.
jerry.hadr
Opus Drum Set M
Příspěvek od jerry.hadr » úte 31. črc 2012 21:24:22
souhlas, pouzivam mikrofony z teto sady a jsem dlouhodobe spokojen. maji univerzalni pouziti od folku po bigbeat, libi se mi, ze nemaji "tuctovy", "audixovy" zvuk. (nic proti audixum, jsou dobre). Prijde mi, ze zvuk je z Beyeru takovy zivejsi, coz je to, co jsem hledal.
Zpět na „Beyerdynamic“
