Mackie DL1608
jonas
Re: Mackie DL1608
Příspěvek od jonas »
Zdravim. Tak jsem provedl upgrade na 7.1.1 a chova se to stejne. Nevydrzel jsem to a napsal technickemu supportu Mackie. Tak jsem zvedav co odpovedi.
Jonas
zahy
Re: Mackie DL1608
Příspěvek od zahy »
podobnou hlášku jsem už taky měl. Nemám sice Mackie ale jenom Ipad, problém jsem zachytil v konektoru, špatný kontak.
jonas
Re: Mackie DL1608
Hezky den. Tak se nakonec zadarilo a postup popsany technickym oddelenim f. Mackie bylo uspesne. Pomohla reinstalace FW v mixaznim pultu. Nyni jiz mix pult nedela zadne problemy pri dokovani iPadu. Pro pripadne zajemce zde prikladam text, ktery poslali:
Hi,
You can try reinstalling the firmware on your mixer. If that does not fix the issue, you can try resetting all settings on your iPad. Be aware that resetting all settings will delete all wifi, user preferences etc. on your iPad, but will not delete apps, photos, media, etc.
To re-flash the firmware please follow the next steps.
To do so, follow the steps below:
1. Power off the DL1608
2. Place your iPad in the dock and open Master Fader.
3. With a paper clip or ball point pen, press and hold the recessed switch found between the power and Ethernet jack.
4. While holding the recessed switch, power on the DL1608, then release after 5 seconds.
5. The master fader will ask to update. Select "yes, update."
Upon doing so, the Master Fader app will reprogram the mixer. It's important that you do nothing to the iPad or mixer until it completes the process as not to be interrupted. Please do not touch anything for about 20 seconds after the window disappears.
POZOR TEN UPGRADE TRVA OPRAVDU DLOUHO!!!! Vypada to, jako by se nic nedelo a presto se tam FW a bootloader uklada. Jedna se o kompletni preflashovani FW v mix pultu.
Jonas
Pawlyk65
Re: Mackie DL1608
Příspěvek od Pawlyk65 »
Zdravím, už někdo "prubnul" aktualizaci na iOS8?...
Pawlyk65
Re: Mackie DL1608
tož si odpovím sám...ověřeno na 2 tabletech..vše v pohodě maká =D>
Re: Mackie DL1608
Příspěvek od Pavel Sedlák »
U mně taky OK.
Dokonce bych řek, že "míň přemýšlí" , ale to chce ještě pár akcí, aby se to nějak projevilo :-)
Bildic
Re: Mackie DL1608
Příspěvek od Bildic »
U mňa zle - zmrznutie resp. reboot. Akciu som dokončil na náhradnom iPade pod iOS7.
Jeden deň fungoval iOS8 bez žiadnych problémov - štandardná práca - Nie s DL. Po pripojení na akcii do DL po cca 10 min fungovania iPad stuhol. Nahodil som iPad mini, DL pracovalo stále bez problémov. Po cca 1 hod sa iPad4 zotavil - rozsvietil (dovtedy mrtvy bez reakcie na reset), tak som ho pripojil cez wifi do DL a pracoval cca 1 hod paralelne s iPad mini na wifi. Testoval som ho, či sa naozaj zotavil a keď som si po cca 1 hod vydýchol, tak zhasol. Potom už ani ťuk - priebežne som ho znervozňoval asi 8hod resetom.
Našiel som na fóre ako zabudiť iPad - cez iTunes. Potom stuhnutia a reštarty aj cez iTunes pokračovali (asi 25 reštartov) - teraz dostal poslednú šancu - obnovujem ho cez iTunes - vraj aktualizovať - novy iOS8.
Na iPad fore je toho už veľa - doporučujem nerobiť testovacích...
j
Pawlyk65
Re: Mackie DL1608
tak u mě sobotní celodenní akce DL1608 + iPad4(iOS8) v doku...+ iPad mini retina(iOS8) přes wifi...bez jediného problému či výpadku.
je fakt, že ani na jednom iPadu nejsou instalované kromě MasterFader2 žádné zbytečnosti, jen na "mini" mám navíc vzdálenou plochu a GoPro aplikaci... 8)
Bildic
Re: Mackie DL1608
tak moj iPad nepatril asi k "vyvolenym" pre iOS8. Uz je v servise - nahodne restarty (spustene aplikacie mail a safari, wifi, jas cca 60%, baterka pod 50%). Pritom pri iOS7 max spokojnost, denne vyuzitie.
Podla info z hotline servisu nie je to nic zvlastne. Po kontrole sa meni v zaruke kus za kus. Mam cakat. :(
Na forach sa niektori stazovali a pripisovali restarty ku wifi (odstranit a nanovo prihlasit), jas do 40%, baterka na min 75%,... :D
Apple a vyvojari uz odhalili prvotne problemy, do konca mesiaca budu prve "lestenia". Komunita AVID doporucuje downgrade na iOS7.1.2., postup ma svoje "muchy".
Bildic
Re: Mackie DL1608
Pre info - odpoved zo servisu - apple uznal vymenu iPadu a mam cakat - do tyzdna poslu nahradu.
Bildic
Re: Mackie DL1608
info II.
vymena OK. iPad servis odovzdal. :-)
iOS 8.0.2 bezi fajn
ma to vsak ale chybicku krasy -> nefunkcny lighting konektor.
Takze nove info zo servisu po ich kontrole - potvrdena vymena vymeneho kusu :-)
cakam dalej.
j
dulla
Re: Mackie DL1608
Příspěvek od dulla »
Zdravim,možno sa to tu už riešilo,ale neviem nájsť...
Kde ukladá iPad nahrávky pri rekordingu? Alebo ako sa k ním dosať? cez iTunes?
Ako upraviť Gain pri púšťaní MP3 z iPadu?
Ďakujem.
deadmeat
Re: Mackie DL1608
Příspěvek od deadmeat »
k nahravkam sa dostanes cez iTunes v zlozke aplikacie, tam kliknes na aplikaciu master fader a v nej najdes zoznam nahravok.
gain na iPad vstupe sa menit neda, ale nerob si starosti s tym ze to ide "do cervena" nakolko to nejde cez predzosilovac tak sa nemusis obavat ze je to prebudene, je to proste len ukazovatel toho s akou hlasitostou mozes pocitat
dulla
Re: Mackie DL1608
Ďakujem...pomohlo :-)
Dá sa nahrávka prehrať ihneď po uložení v iPade?
Alebo musím ísť stále do iTunes do PC?
deadmeat
Re: Mackie DL1608
Neda, z iPadu niesu nahravky pristupne, su ulozene v aplikacii nie v hudobnej kniznici (tiez by som bral keby sa to dalo pustat priamo) jedina moznost je ist do iTunes, ulozit do PC a potom vlozit do iPadu do hudobnej kniznice
Zpět na „Mackie“
