futurelight DJ-Scan 210
Zdravím.
Chtěl bych všechny přítomné poprosit. Nemá někdo k těmto scanům (futurelight DJ-Scan 210) manuál nebo maximálně jejich DMX protokol.
Předem děkuji
Předem děkuji
janek
Re: futurelight DJ-Scan 210
francuzsky manual: http://www.mgconcept.fr/boutique/djscan210.pdf
vyzera ze protokol je: 1 kanal pan, 2. tilt. 3. farby+raibow, 4 gobo+strobo+shutter
vyzera ze protokol je taky isty ako dj-scan 200.
tu je definicia pre QLC+ ked dobre popozeras, najdes tam anglicku verziu protokolu https://github.com/mcallegari/qlcplus/b ... can200.qxf pripadne si nainstaluj QLC+ a otvor si tu definiciu.
3. kanal:
<Capability Min="0" Max="10">White</Capability>
<Capability Min="11" Max="21">Cherry Red</Capability>
<Capability Min="22" Max="32">Yellow</Capability>
<Capability Min="33" Max="43">Dark Blue</Capability>
<Capability Min="44" Max="54">Light Green</Capability>
<Capability Min="55" Max="65">Pink</Capability>
<Capability Min="66" Max="76">Purple Blue</Capability>
<Capability Min="77" Max="87">Red</Capability>
<Capability Min="88" Max="98">Pale Yellow</Capability>
<Capability Min="99" Max="109">Light Blue</Capability>
<Capability Min="110" Max="120">Orange</Capability>
<Capability Min="121" Max="127">Dark Green</Capability>
<Capability Min="128" Max="191">Forward Rainbow Speed</Capability>
<Capability Min="192" Max="255">Backward Rainbow Speed</Capability>
4. kanal:
<Capability Min="0" Max="7">Closed</Capability>
<Capability Min="8" Max="15">Open</Capability>
<Capability Min="16" Max="23">Gobo 1</Capability>
<Capability Min="24" Max="31">Gobo 2</Capability>
<Capability Min="32" Max="39">Gobo 3</Capability>
<Capability Min="40" Max="47">Gobo 4</Capability>
<Capability Min="48" Max="55">Gobo 5</Capability>
<Capability Min="56" Max="63">Gobo 6</Capability>
<Capability Min="64" Max="71">Gobo 7</Capability>
<Capability Min="72" Max="79">Gobo 8</Capability>
<Capability Min="80" Max="87">Gobo 9</Capability>
<Capability Min="88" Max="95">Gobo 10</Capability>
<Capability Min="96" Max="103">Gobo 11</Capability>
<Capability Min="104" Max="111">Gobo 12</Capability>
<Capability Min="112" Max="119">Gobo 13</Capability>
<Capability Min="120" Max="127">Gobo 14</Capability>
<Capability Min="133" Max="137">Reset after 3-5 seconds</Capability>
<Capability Min="138" Max="159">Forward Gobo Change Speed</Capability>
<Capability Min="160" Max="200">Strobe Speed</Capability>
<Capability Min="201" Max="250">Random Strobe Speed</Capability>
<Capability Min="251" Max="255">Open</Capability>
3. kanal:
4. kanal:
ked som to vcera skusal googlit tak mi ukazalo, ze ako keby boli v dvoch tvaroch - vonkajsia skrinka
A podla toho co pise Janek, mam pocit ze sa to aj podoba na ADj DJScan 250
http://smefata.sk/efata-band/
A nemá někdo hotový formát do Freestyleru 512? tam taky není. Pokud nebude, tak si ho budu muset vytvořit.
Ještě jednou dík za návod
Mohl by se mi ozvat někdo, kdo tyto scannery používá?
řeším problém. Jeden přestal pracovat , na spodním displeji svítí jen D 001 a nereaguje na povely tlačitky a lampa nesvítí. S vítí červená dioda vedle displeje. Co by tomu mohlo být.
Opravuje někdo tyto scanery, jsou na ně někde náhradní díly?
ze by si skusil sa opytat aj na FB v skupine Osvetlovaci
