Ruzne *filly
Ruzne *filly
Příspěvek od safa »
Dostal se mi do ruky rider Tarji Turunen (mimochodem pouziva Beyerdynamic na zpevech a na bicich) a zaujaly mne pozadavky na vykrejvky. Uvedomil jsem si ze o nekterejch *fillech ani nevim co znamenaj ... tak ze ptam co presne pokrejva:
FRONTFILL (chapu spravne jako vykrejvku kotle z forbiny pokud tam nedostreli MAIN PA ? )
INFILL
OUTFILL
Vedle DRUMFILLU a SIDEFILLU mi to prijde nejak "preFillovano" (nic osobniho, Filipe ;-) )
Fyla
Příspěvek od Fyla »
Ses si jistej, ze tam nemaj naspsanej pozadavek na:
OUTLET of INDOOR OUTSIDERS? :)
(jinak jsem o tom vzivote neslyslel)
Příspěvek od safa »
Tady to mas v originale:
Minimum of 110 db(A) undistorted sound at FOH
-The power of the system has to be calculated to maintain adequate headroom through full
frequency range considering the size of the room
- The coverage of the system has to be even through the whole listening area
- Frontfills / infills has to be used because of quiet stage sound (vocals)
- Outfills has to be used if the listening area is wide.
- Fills must be driven through sepatate EQ, HPF and system delay. Signal from aux or matrix send.
Fyla
Příspěvek od Fyla »
Front fill - doplnek hlavniho PA pred podiem - se stejnym mixem.
In fill - doplnek hlavni PA pred podiem - s jinym mixem - kompenzace tichych nastroju k hlasitym (to, co hraje akusticky z podia)
Out fill - typicky vykryvka na bocni tribuny v halach...
